My right hand turn signal flashes fast on the front and the rear. Is this a bulb?
May 24, 2019 at 10:33 AM
✓Experienced Mechanic
Welcome to 2CarPros.
The system is designed to "double time" when there is a burned out bulb. Have you check all of them? Compare it to the side that is working normally to see if there is one burned out.
