right front wheeel speed sensor
103,000 MILES
S90346ER
I have a completely corroded rt.front speed sensor. I have slight pull to left when braking. What do you think ? Some one has changed one of caliper units. I replaced rotors and pads( noticed failed sensor) Iplan to replace sensor.
Apr 29, 2013 at 8:34 PM
HMAC300
  • 48,601 POSTS
if you car pulls to left then check right caliper for frozen or which ever one was replaced. both should have been done at the same time. also check the brake hoses as that could be problem as well. if the sensor is corroded but still no abs light just clean the corrosion up.
Apr 29, 2013 at 10:45 PM
S90346ER
Thanks, I replaced sensor, I will replace front calipers.
Apr 30, 2013 at 9:48 AM
