right front vibration between60-75 mph
300,000 MILES • 2.3L • 4 CYL • RWD • AUTOMATIC
WALKER1980
after hitting an animal(fox???) on interstate doing 81 and becoming slightly airborne for about .5 seconds i have noticed a vibration on the right(pass) front end. nothing is noticable as being damaged and im assuming i hit the animal head on in the center. what could be causing the vibration or better put as a shimmy. i dont notice it much in the steering wheel and its more pronounced if im doing between 55-75 mph.
all inner, outer tie rods as well as both ball joints new as of nov. 2014.
what could be damaged if anything???
Apr 9, 2016 at 4:40 PM
HMAC300
  • 48,601 POSTS
have the front end checked it may have bent a control arm or damaged a ball joint which need to be tested a certain way could have also bent a wheel slightly or knocked a weight off wheel for balance.
Apr 10, 2016 at 1:49 AM
WALKER1980
thx ill check those components over. the funny thing is that sometimes it wont vibrate at all and others it will. yesterday i was doing 51 and it was very bad but doing low speeds it does not vibrate at all.
Apr 10, 2016 at 6:51 AM
