Whenever I go over a big bump, I get a big slamming sound from the right front side of the car. Based on my experience 6 years ago, this means the right front strut is going out. When this happened before, the whole mounting plate was busted out and the strut was very loose. Could you tell me what all to check to verify that the right front strut is going bad? Also, could you recommend some brand of struts to replace it with? I replaced all 4 struts in 2018 with a budget brand called Elite. Looks like it was about $240 for all 4 struts at the time. So I will probably get something similar this time around and replace all 4 again. I will go with the complete / quick struts that are already compressed and include the mounting plates. I was mostly just wondering if you knew of any brands that are affordable and also reliable.
May 25, 2024 at 12:14 PM
