When my vehicle car is moving, i heard some disturbing noise at the right front wheel. it sounds as if the shocks are bad.
i changed the shocks, arm, ball joints. the noise did not go away.
So i decide to check the right front shaft, when i pulled it out, it was stone dry. No transmission fluid oil on it.
My question is, should it be dry?
Jan 2, 2019 at 2:57 AM
