Riding pretty rough, seems like theres resistance or hesitation in acceleration.
163,600 MILES • 6 CYL • AUTOMATIC
MEGAN GIETZEN
My car has been slightly hesitating upon acceleration, sometimes it will get to 3000 rpm's before it even hits 25 mph. Tonight it started chugging really bad, as if I was low on fluids and the check engine light came on and beeped and flashed. I chugged into a gas station and checked my fluids, they are fine. Put gas in. Still did it. I do need my rear brakes done badly, but that could not be the problem, could it?
Jun 12, 2016 at 6:05 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts can scan for free and rent the gauge. it may be a fuel pump problem or regulator also check for vacuum hoses broken/disconnected or cracked.
Jun 13, 2016 at 12:04 AM
