engine revving up and down up and down rapidly
200,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
MPLAIN
  • 24 POSTS
As soon as the van is started the van revs up and down up and down rapidly.
Jan 24, 2017 at 6:58 AM
STEVE W.
  • 15,413 POSTS
Common issues on this vehicle that can cause this.
The first is a broken wire(s) for the power steering pressure sensor. They corrode and break off. The sensor is at the passenger side of the car on the power steering pressure line. The solution is to repair the break which usually requires a new connector pigtail unless you have the tools to replace the terminal ends.
Another issue is a dirty Idle air control valve. Not difficult to remove it and clean it out.
Next would be the EGR valve, the passages and the valve itself have caused issues with idle surge.
Usually the CEL will come on but not always.
Jan 25, 2017 at 7:41 AM
