Revs up and down while driving or idling
100,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
CHAMELEON9
Engine sounds like it is revving for about five or so seconds every thirty seconds to a minute, no matter if it is idling or driving.
Jun 11, 2018 at 10:36 AM
BMDOUBLE
  • 1,139 POSTS
I have replaced many throttle position sensors for this concern. To verify this is the concern you need to connect a scan tool that is capable of displaying the throttle position sensor volts and mode. Also, more than likely it will not set a trouble code because it is an in spec failure. The bad ones that I have has will show part throttle when the throttle is closed. I hope this helps.
Jun 11, 2018 at 12:44 PM
