Rev high and it doesn't go
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Start by verifying the transmission fluid type and level using the procedure for the exact transmission fitted to this vehicle. Tell the shop what fluid was added and approximately how much. Avoid adding more fluid by guesswork or repeatedly revving the engine to make the vehicle move. Since the level was reported low, have the transmission and its fluid lines inspected for leakage. If a leak is found, repair it and set the fluid level correctly before evaluating operation again. Correcting the level may help, but it cannot reverse any internal damage already present. If the vehicle still will not engage properly, have a transmission-capable scan tool check for faults, followed by the manufacturer's diagnostic tests. Internal damage remains possible, but the symptoms alone do not establish that a replacement transmission is necessary. Arrange transport if the vehicle cannot move reliably. A verified fluid level, leak inspection, and diagnostic results will give you a much firmer basis for choosing a repair and avoiding an expensive guess.
Guidance references and applicability
Original discussion, supplied source snapshot: https://2carpros.com/questions/revs-high-69067255--1713501 Documents high engine speed without expected movement and the owner's report of low transmission fluid. The replacement recommendation in the replies is not a confirmed diagnosis. ZF Aftermarket, Transmission Oil Check (consulted 2026-10-11): https://aftermarket.zf.com/en/aftermarket-portal/knowledge-hub/transmission-oil-check/ Supports investigating fluid loss and inspecting for leaks. It is general supporting information, not proof that this vehicle has a ZF transmission and not a fluid specification for this vehicle. The sequence above is diagnostic reasoning. Verify the installed transmission, approved fluid, level-check conditions, and test procedures in the vehicle manufacturer's service information. No particular replacement unit or repair is prescribed without test results.
Discussion summary
The owner reported that engine speed rose when the accelerator was pressed but the vehicle did not move as expected, as though it was not engaging a gear. The owner had added transmission fluid and later confirmed that the level had been low and that they had never had the transmission serviced. A contributor discussed possible internal transmission damage, requested a video of the symptom, and later suggested a replacement transmission based on the reported symptoms.
Reported outcome: Internal transmission failure was suspected in the replies, but no diagnostic test results, replacement, or successful repair were reported.
The discussion does not confirm the cause of the low fluid level or establish that transmission replacement is necessary. The proposed diagnosis was based on the description rather than reported inspection or test results.
