Reverse problem with Transmission
119,350 MILES • 3.0L • V6 • 4WD • AUTOMATIC
PANDORASBOX9
When I start to back my car up I'm getting a vibration and hesitation especially when I'm turning the wheel. What is causing that? I just bought the car.
Nov 9, 2019 at 2:41 AM
  • 110,251 POSTS
Hi:
Are there any noises associated with the issue? For example. do you hear any clicking or knocking sounds?
Nov 9, 2019 at 2:06 PM
PANDORASBOX9
No, I don't hear any clicking or knocking noises. Once I engage reverse it revs up and then it makes a clunk noise and the steering wheel starts vibrating especially when I'm turning the car.
Nov 10, 2019 at 3:10 AM
  • 110,251 POSTS
Hi:
Based on the description, it sounds like an axle/CV joint issue. It's odd that it doesn't happen in drive but anything is possible.
Do me a favor. Take a look through this link and let me know if it seems to mirror what you are experiencing.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
I will watch for your reply.
Nov 10, 2019 at 12:36 PM
