Reverse lights not working
150,000 MILES • 4.3L • V8 • 4WD • AUTOMATIC
VIOLET ASBURY
The reverse lights on my truck are not working. The bulbs do not appear blown and the fuses also do not appear blown. Thanks in advace
Nov 1, 2016 at 3:23 PM
HMAC300
  • 48,601 POSTS
check items in picture and grounds also check ground on left hand rear body mount if still not working check junction block at left hand rear frame rail connection and finally have scanned for a body module problem. also make sure to check the bulbs as well.
Nov 2, 2016 at 12:20 AM
VIOLET ASBURY
Thank you so much for your reply! After checking grounds we discovered the bulbs had corroded where they connect in the housing.
Nov 4, 2016 at 9:14 AM
  • 55,711 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Best, Ken
Nov 7, 2016 at 12:51 AM
