Reverse lights do not work
250,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
HENRY THEROUX
The reverse lights do not work in my vehicle. I have checked the fuses and bulbs, I do not think it is the neutral safety switch because the vehicle starts fine and shifts fine.
May 23, 2016 at 1:35 AM
HMAC300
  • 48,601 POSTS
with the wheels blocked put the transmission in to reverse and turn key on see if wire marked is getting power, if not the switch is bad.
May 23, 2016 at 2:39 AM
