Backup camera and reverse light stay on all the time, why is that?
100,000 MILES
CORRIE1981
Reverse lights.
Feb 17, 2023 at 4:27 AM
  • 110,248 POSTS
Do they stay on if the vehicle is off, and the key is removed? Also, when you shift gears, does the gear indicator indicate the correct gears?
I attached the wiring schematic below for the backup lamps. If you remove fuse 1 in the under-hood fuse box, do the lights and camera turn off?
Feb 17, 2023 at 1:30 PM
