Reverse light, camera and parking sensors do not work?
50,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ADDYRICKS
The reverse light, camera and parking sensors don't work, my guess is the reverse light switch on the gearbox is faulty. The engine seems a bit tucked back in the engine bay, I'm wondering how can I get at the reverse light switch to replace it.
Aug 21, 2024 at 4:26 AM
  • 55,710 POSTS
We don't have too much info on this car. It does sounds like the gear range sensor is the problem though which is unusually on the transmission near the gear selector cable connection. If you upload images I can help walk you through the repair.
Aug 22, 2024 at 2:45 AM
ADDYRICKS
I'm guessing this is faulty. the reverse switch. The image is from eBay and not my actual gearbox but one of the same model. I'm wondering, how I go about getting access to it to replace it? can I get it from the engine bay? what do I need to take off to get at it?
Aug 22, 2024 at 5:55 AM
  • 55,710 POSTS
Yep, that looks like it, you should be able to get to it by removing the air filter box and ducting, but if you lift your hood and give me images, I can help walk you through it.
Aug 23, 2024 at 12:10 AM
ADDYRICKS
Hi Ken, after checking bulb and connector in the boot I got to the engine bay, the cable leading to the reverse light switch was broken, I took off air filter and took battery cover, battery, battery base out for better access, disconnected switch and spliced the wires back together and that fixed my issue...thank you for taking the time to reply to me, greatly appreciated.
Aug 23, 2024 at 2:04 AM
  • 55,710 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Aug 23, 2024 at 6:16 AM
