Reverse gear problems
70,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
JOHNCROLL
It is very difficult to engage reverse.
When i attempt to do so the gear lever will nearly always refuse to "click" into position.
If i am fortunate to be parked on a slope with the car facing upwards and i let the car drift gently backwards it will then engage.
Also, if i stop the engine and then try to select reverse, it will sometimes go into position. I can then start the engine and go backwards.
Any suggestions please?
Dec 29, 2017 at 8:11 PM
  • 31,937 POSTS
The clutch may be worn, when in gear if the drive takes up with the pedal well off the floor. this is a sign that the clutch is worn. what does yours do?
Dec 29, 2017 at 8:28 PM
