Reverse gear loud screeching noise and no movement
155,000 MILES • 0.5L • 4 CYL • 2WD • MANUAL
MRBKE2008
When I go into reverse, I get a loud screeching noise and no movement. It doesn’t do this all the time, but is more common than not. It also shifts in all other gears with no problem. Can I fix this myself?
Jan 19, 2019 at 12:24 PM
Good morning,
The issue could be either a band or a clutch drum inside the transmission.
Yes, If you can remove it and disassemble it, you could do it yourself. It is a major repair.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
I attached a picture of the area that is suspect.
Jan 20, 2019 at 12:52 AM
