Reverse/forward transmission issues
JBC4334
  • 2007 CHEVROLET COLORADO
  • 5 CYL
  • 4WD
  • 68,000 MILES
Started having a problem with my truck. Whenever I change gears to either drive or reverse my truck is sluggish and feels like the e brake is on and tires start to spin at higher rpm's, however the truck does not want to go forward or backward. I change the gears a few times and it eventually straightens out. It is an automatic. The truck shifts fine in all forward gears. It just occurs when I change gears either starting off or backing into a parking spot. Transmission fluid is good. Does anyone have any ideas or had similar issues? I am sure the gear selector Ford is correct too.
Wednesday, November 28th, 2018 AT 1:57 PM
  • 52,797 POSTS
Good afternoon,
The first thing I would do is to change the fluid and filter. The filter being clogged will cause this issue.
Beyond that, is there any codes stored for the transmission?
Wednesday, November 28th, 2018 AT 2:04 PM
