It has been long for a while now.
But I discovered that the engine oil is low though it is a little bit higher that the low marked line on the stick for checking the Oil gauge. Its not even close to the full marked line on the stick. I checked it this morning.
Aug 23, 2019 at 7:00 PM
✓Experienced Mechanic
Engine oil level has nothing to do with the transmission operation.
Aug 23, 2019 at 9:13 PM
ALAO
MEMBER
Thank you sir. But it has been long the car is serviced (changing of the engine oil). I also discovered this light showing on the dashboard screen.
