Reverse gear not selecting
115,000 MILES
ALAO
When I put it on drive, it moved forward, but when I try to put it on reverse it will not move but jerking.
Aug 23, 2019 at 12:59 AM
Good afternoon,
How long since you changed the fluid and filter? I would start there.
Are there any codes?
Aug 23, 2019 at 2:24 AM
ALAO
It has been long for a while now.
But I discovered that the engine oil is low though it is a little bit higher that the low marked line on the stick for checking the Oil gauge. Its not even close to the full marked line on the stick. I checked it this morning.
Aug 23, 2019 at 7:00 PM
Engine oil level has nothing to do with the transmission operation.
Aug 23, 2019 at 9:13 PM
ALAO
Thank you sir. But it has been long the car is serviced (changing of the engine oil). I also discovered this light showing on the dashboard screen.
Aug 24, 2019 at 6:46 AM
What light?
Can you post a picture for me to see?
Aug 24, 2019 at 6:52 AM
