Rev limiter
10,000 MILES
SHELBYGT08
  • 11 POSTS
My gas pedal got stuck under my floor mat causing the engine to redline for about 2 seconds before I could react because it freaked me out. I quickly shut the engine off and realized what happened restarted the car while I was rolling it’s a 5-speed. Isn’t the rev limiter supposed to save the engine in a situation like this? I’m thinking the motor didn’t get damaged. Your thoughts would be great thanks.
Nov 29, 2020 at 6:55 AM
BMDOUBLE
  • 1,139 POSTS
That's the general purpose of the rev limiter. But I cannot say this for sure because I can't see or hear your engine running. When I was on the technician review panel for Ford we toured the powertrain plant and got to see how they test engines and transmissions, which was an eye opener because they had several engines being taken to redline then to idle over and over by a machine for several days! So my guess is that if it sounds like it did before, you're probably good.
Nov 29, 2020 at 7:43 AM
STEVE W.
  • 15,410 POSTS
The rev limiter will work in the situation you had where the throttle is the controlling input. Where the rev limiter will not help would be if you mechanically ran the engine over the redline, that would be possible if you were driving along at say 55 mph and accidentally shifted down into first or second gear. In that situation the limiter won't do anything because the PCM isn't in control. It wouldn't matter if it shut off the ignition or fuel as neither one of those could slow the engine at that point.
Nov 29, 2020 at 8:18 AM
