2001 Ford Mustang reving up
MWJAMES1
  • 2001 FORD MUSTANG
  • V8
  • MANUAL
  • 135,000 MILES
Hey I have a 2001 mustang bullitt. Ok some times it will start to idle at around 2000rpm and when I change the gears going down the road it revs up to around 3000rpm. Havent lost no power just tryin to get this fixed. I was told it was the sencor on the throttle body.
Saturday, February 6th, 2010 AT 3:33 PM
  • 109,885 POSTS
Has the check engine light come on? To me it sounds like a throttle position sensor (TPS) or idle control valve (IAC). However, it should set the check engine light.
PS: Have you checked for vacuum leaks?
Sunday, February 7th, 2010 AT 11:53 PM
