Retrieval of bolt that was dropped and landed in the flywheel assembly
178,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
CHRIS2020
Drop starter bolt in behind the starter into flywheel assembly need to know how to retrieve the bolt.
Oct 28, 2020 at 5:39 AM
Good afternoon,
You can try a long magnet that is flexible that you can insert and direct it down to where the bolt landed.
You may have to work around different areas as the bolt could bounce around.
You can get the magnet at a part store.
Oct 28, 2020 at 6:07 AM
