Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Flywheel
Bolt
Retrieval of bolt that was dropped and landed in the flywheel assembly
2009 DODGE CARAVAN
178,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
CHRIS2020
MEMBER
Drop starter bolt in behind the starter into flywheel assembly need to know how to retrieve the bolt.
Oct 28, 2020 at 5:39 AM
Experienced Mechanic
Good afternoon,
You can try a long magnet that is flexible that you can insert and direct it down to where the bolt landed.
You may have to work around different areas as the bolt could bounce around.
You can get the magnet at a part store.
Oct 28, 2020 at 6:07 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
