Rethread spark plug hole and added insert?
AUTOMATIC
SAUL LOPEZ
How long do I need to wait to start car after rethreading spark plug hole and adding insert with loctite
Sep 30, 2026 at 8:34 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
For someone undertaking the same repair, first identify the exact insert kit, spark-plug seat type, and adhesive or sealer specified by the kit manufacturer. Match the installation and cure instructions to those products before starting the engine; product color alone is not an adequate basis for substitution or waiting time. Before first start, have the repair checked for correct insert installation, plug fit and tightening, and removal of machining debris using the kit's procedure. Do not rely on a generic compressed-air step as proof that the cylinder is clear. For this owner, the reported smooth running is encouraging. Keep the insert and adhesive details with the repair records, and have any new misfire, puffing at the plug, or loosening investigated promptly. There is no reason in this discussion alone to dismantle a repair that is operating normally.
Guidance references and applicability
Henkel LOCTITE 271 technical data sheet: https://datasheets.tdx.henkel.com/LOCTITE-271-en_GL.pdf Explains the product's threadlocking application and cure behavior. It does not approve substituting 271 for the adhesive specified by an unidentified spark-plug insert kit. TIME-SERT spark-plug repair instructions: https://www.timesert.com/html/howtosp.html Shows that sealer requirements differ with insert design. This is an example of manufacturer-specific installation requirements, not evidence that the owner used a TIME-SERT kit. Follow the instructions for the actual kit.
Read the replies · Discussion summary and reported outcome
MECHTRIX
  • 602 POSTS
Most loctite sets in 30 mins but isn't completely cured for vibratiin and heat for 24 hours thats for the standard high strength (red stuff) ..so it depends on what type you used i go with the old rule of thumb ...(the stronger the longer ) there are some loctute products that take evan longer like up to 62 hours ...hipe this help good luck
Oct 1, 2026 at 2:37 AM
MECHTRIX
  • 602 POSTS
Opps I meant to say the cure time can be up to 72 hours for some loctite products like the green stuff..also if yiu want to speed up the curing time .also the make a quick harder called 7471 that works well and also
be aware that especially with the stronger types of loctite ..
if you ever want to take it back off youl most likely need heat about 500 degrees applied for 3 to 5 mins or so to get it soft enough to remove again ...good luck
Oct 1, 2026 at 3:03 AM
SAUL LOPEZ
I'm having a hard time finding 272 loctite will 271 work
Oct 1, 2026 at 12:21 PM
MECHTRIX
  • 602 POSTS
Yes " The standard high strength (red stuff) is 271.. it will suffice..just kake sure everything it strait in the hole .
And just a side note "
Try to Make sure you dont get any metal burs/ shavings/swarf in the spark plug hole while doing this if you think anything fell inside there you need to remove it completly or damage will occur somtimes you can blow it out with compressed air and a blow gun anyway good luck with your project let us know what you find .
Oct 1, 2026 at 3:49 PM
MECHTRIX
  • 602 POSTS
And if i may add" as just a suggestion not sure what youre using but i dont recomend helicoils for spark plugs hole repairs..instead the best inserts are called "time certs " theyre more like a solid tube thats theaded inside and on the outside there a more solid permanent repair and dont have any of the problems the other types bring with them
Good luck hope this helps
Oct 1, 2026 at 4:00 PM
SAUL LOPEZ
Happy to say the project went well.car is running with no issues now. thank you for the advice
Oct 2, 2026 at 3:45 PM
MECHTRIX
  • 602 POSTS
Gret job keep up the good work glad it worked out for you we're always here to help let us know if theres anything else we'll see what we can do
Oct 2, 2026 at 7:06 PM
Discussion summary
The owner asked how long to wait before starting the engine after repairing a spark-plug hole with an insert and threadlocker. The owner later asked whether LOCTITE 271 could substitute for 272. Contributors discussed cure time, avoiding machining debris, and insert types. The owner subsequently reported that the project went well and the car was running without issues.
Reported outcome: Owner-confirmed short-term success: the owner reported that the car was running without issues after the repair.
The final insert brand, adhesive used, cure conditions, and long-term result were not reported. The successful outcome does not verify every product-substitution or cure-time statement in the replies.
Read the original discussion
