accidentally Factory Setting and now it is in German not English
2014 VOLKSWAGEN PASSAT
45,000 MILES
ANITA CVITKOVIC
I have press accidentally Factory Setting and now it is in German not English. How do I reset it back?
Dec 27, 2016 at 11:07 AM
  • 55,214 POSTS
Hey ANITA,
To change the language of the car go into setting in the information center. There should be mire detailed instructions in your owners manual.
Please let us know what you find so it will help others.
Best, Ken
Dec 31, 2016 at 6:14 AM
STEVE W.
  • 15,295 POSTS
This is the method for many of the VWs with an MFD display. Start with the ignition off.
Start the car-
If you look at the wiper stalk (right one) it has a trip rocker button at the end. Push in on the bottom rocker for 2 seconds to get the settings screen. (it will say einstellungen not menu) then click the OK button (located on the bottom of the same wiper stalk)
Now use the rocker switch to scroll the screen to find Sprache/Lang and click OK. Scroll to English and click OK. You should now see the display in English.
To do the same thing with the steering wheel controls you start the car and press the RIGHT arrow on the right hand control. This will open the settings menu the first option should be language, scroll up down with the up/down arrows. Find English and hit the center button on the control to select.
Dec 31, 2016 at 10:20 AM
  • 55,214 POSTS
Nice work Steve W.
Happy new year!
Dec 31, 2016 at 10:22 AM
ANITA CVITKOVIC
does not work, must need a computer reset?
Nov 25, 2023 at 2:56 AM
STEVE W.
  • 15,295 POSTS
At which step did it fail? That method should allow you to change the language displayed on the dash. If the menu option didn't work it is possible to reset it using a factory level scan tool as well.
Nov 25, 2023 at 3:13 AM
