Resetting the TCM
200,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ELFMAN
Was told I can reset the computer by jumping 2 terminals after changing the 1-2 shift solenoid. What 2 terminals?
Mar 26, 2020 at 2:33 AM
Good morning,
there is no resetting the TCM at all. There is reprogramming but that is done with a factory scan tool.
You can remove the negative battery cable for a minute and reinstall. That will make the TCM forget the code for the time being.
If your repair was correct the light will go out. If it is not correct, the light will remain and further diagnostics are required.
Mar 26, 2020 at 2:51 AM
