reset security system
85,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
SONEY88
I did all reset suggestions and still did not work.
Aug 17, 2019 at 7:12 AM
  • 110,251 POSTS
Welcome to 2CarPros.
Does the engine crank and not start? Was anything done prior to this issue? For example, someone jumped started the car and reversed the cables?
Did you try ignition on for 10 minutes to see if the anti theft light turns off?
https://www.2carpros.com/articles/how-to-reset-a-security-system
The BCM can be causing the issue as well as the theft control module. To eliminate the theft module from causing the BCM problem disconnect the Low Speed LAN coming from the Theft Module at the C3 connector PIN 10 and recheck BCM communication. Visa-versa for the theft module to see if it's the BCM shorting the theft module.
Let me know what is happening.
Aug 18, 2019 at 2:02 PM
PISSYSUE
I got in my car yesterday and went to the store. I came back home and later I went out to go to the doctor's office. My car would not crank. The security light keep flashes on panel and when I turn the key in the ignition it will not start.
Mar 12, 2021 at 1:03 AM (Merged)
RENAUDTN
  • 636 POSTS
your passlock system (theft deterrent system) is triggered.
Try to reset it:
-Turn key like you're gonna start the car
-let key back in the run position until the security light stops flashing (about 10 minutes).
-when security light turns off, turn key to OFF for five seconds
-turn key like you're gonna start the car again and repeat the same procedure for another two times (3 relearns total, about 30 minutes)
On the last relearn turn key to OFF for five seconds like you're supposed to, then on the next attempt to start the car the system will 'relearn' the passcode/proper resistance, and your car should start.
If it doesn't work, you'll need to have your car checked at a dealer; you may have a defective passlock sensor, bad connection at the BCM, bad ignition lock cylinder/switch.
Also, I'm not sure, but the owner manual may have the relearn procedure in it. You may want to check.
Hope this helps
STANP_CHILI32
My security warning has been coming on periodically and it stays on for about 10 - 30 minutes, sometimes even stopping the engine from starting. What is the problem?
Mar 12, 2021 at 1:05 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Ignition switch need to have it replaced if you get stuck and will not start for you turn key ON for about 10 min and you should be able to start after that plus check this guide out to help reset the system
let us know what happens
CHERBEAR9294
How do you reset the theft system? Somehow the system was triggered and I can't start the car now. I tried turning switch on and letting it set for 15-20 minutes and this did not work.
Mar 12, 2021 at 1:06 AM (Merged)
RENAUDTN
  • 636 POSTS
the official GM passlock relearn procedure is as follow:
1. Turn ON the ignition, with the engine OFF. Attempt to start the engine, then release the key to ON (vehicle will not start).
2. Observe the SECURITY light, after approximately 10 minutes the light will turn OFF.
3. Turn OFF the ignition, and wait 5 seconds.
Turn key to START; sometime your car will start after only one relearn. If so ,you're done. If not, repeat steps 1 to 3 two more times (for a total of 3 relearns). A that point, the vehicle will be ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to START.
Important
The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
This guide can help as well
Hope this help
CHRIS MCCONNAUGHEY
I replaced my radiator did not unplug battery after replacement was done car had power, but would not start reset anti theft by turning ignition to Acc with radio off push button on radio for ten seconds menu came on went security off. pressed button security light went away now car still will not start and now no security light either.
Mar 12, 2021 at 1:08 AM (Merged)
CHRIS MCCONNAUGHEY
My dad is with me he is the certified master tech.
HMAC300
  • 48,601 POSTS
you may have to do the reset a twice or three times electronics are funny if it still will not start you will need a pro scanner to see what the problem is. here is our dandy little link to help.
LAKESHO04
my car will never start how do you disable the pass lock system
Mar 12, 2021 at 1:09 AM (Merged)
RENAUDTN
  • 636 POSTS
Is your security light blinking?
Have you tried the GM passlock relearn procedure?
-turn your key to 'start' and let key go back to 'run'
-wait until the security light goes off (about 10 minutes)
-turn key off and wait 5 seconds
-repeat same procedure two more times for a total of 3 relearns.
On the third time, after you turn your key off for 5 seconds and turn it back to 'on', your system relearn the code and your car should start.
If it doesn't work, you may need to get a new passlock sensor, or possibly a new ignition switch/lock cylinder. Take it to a dealer and tell them about your problem. This no start condition due to the passlock system is very common. I just want to let you know in case the dealer tells you he never heard of it.
J_TEETS
Hello, I have had the above Impala for 1 1/2 years. I have replaced two starters in it the last one was lifetime warranty. The issue is periods where it wont start, I turn the key dah lights all light then when turned to start nothing happens. I take out the key reinsert several times. The SECURITY light comes on periodically for no apperent reason. I wondering if ther is a link between the two or maybe my problem is in the IGNITION?
PLEASE HELP
Jessica
Mar 12, 2021 at 1:16 AM (Merged)
RENAUDTN
  • 636 POSTS
Your problem is probably your theft deterrent system. This is a very common problem on chevy cars (and others for that matter). Here are some solutions I gave someone else on this site with the same problem:
* Go to a dealer and get charged a ridiculous amount of money for a diagnosis and a fix that may or may not work.
* Try the GM reset procedure for passlock:
• Turn ON the ignition, with the engine OFF.
• Attempt to start the engine, then release the key to ON; the vehicle will not start.
• Observe the security telltale; after approximately 10 minutes the telltale will turn OFF.
• Turn OFF the ignition, and wait 5 seconds.
• Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the car may start after only one time though); the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
* Bypass the system (check online for infos)
* Attempt to fix it your self, in which case you'll have to determine what's wrong: passlock sensor, ignition cylinder, BCM, bad connection, etc
RCARLS12
Car gets power and battery is charged. Go to turn key and it will not turn over or start.
Mar 12, 2021 at 1:17 AM (Merged)
Relearn procedure below.
PROGRAMMING THEFT DETERRENT SYSTEM COMPONENTS
PROGRAMMING REPLACEMENT PASSLOCK SENSOR, BCM, OR PCM
IMPORTANT: The body control module (BCM) must be programmed with the proper RPO configurations before performing learn procedures. Refer to Body Control Module (BCM) Programming/RPO Configuration. See: Body Control Module > Programming and Relearning > Body Control Module (BCM) - Programming/RPO Configuration
IMPORTANT: If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn Passlock sensor data code immediately. The existing PCM however, must learn the new fuel continue password when the BCM is replaced.
IMPORTANT: If replacing a PCM with a GM Service Parts Operations (SPO) replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password and will require a learn procedure after programming to learn the current vehicle's password.
CONDITIONS
Use this procedure after replacing any of the following:
- Passlock Sensor
- BCM
- PCM
LEARN PROCEDURES
There are two available methods to perform the programming procedure:
- A 10 minutes procedure which requires a Tech 2 and a techline terminal.
- A 30 minutes procedure which does not require the use of any tools.
10 MINUTE LEARN PROCEDURE
TOOLS REQUIRED
- Tech 2
- Techline terminal with current SPS (Service Programming System) software
1. Connect the Tech 2 to the vehicle.
2. Select "Request Information" under "Service Programming".
3. Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
4. On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
5. Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
6. Turn ON the ignition, with the engine OFF.
7. Select "VTD Re-Learn" under "Service Programming".
8. Attempt to start the engine, then release the key to ON (vehicle will not start).
9. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF (the vehicle is now ready to relearn the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK).
10. Turn OFF the ignition, and wait 5 seconds.
11. Start the engine (the vehicle has now learned the password).
12. With the Tech 2 (scan tool), clear any DTCs.
30 MINUTE LEARN PROCEDURE
TOOLS REQUIRED
None
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
IMPORTANT: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlock Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
IMPALAMAMA
Ok where do I start about a month ago we had AAA replace a dead battery, shortly following that the security light would come on randomly, then the trunk would not open, had to use a key manually. Then the doors would not open had to use key manually. Now car dosn't start, lights come on on dash, no clicking. I put in acc or on mode and now message center says service traction system yikes now what. remote will not function to lock or unlock doors now. Don't want to replace starter if it is not that, so many post indicate security issues with these cars but dealers can't seem to fix after hundreds of dollars on parts and service which does not resolve issue. And being a female I'm sure they would have me buy a new vehicle, (well after parts and service that would be like buying a new vehicle).
JERRYGOODWRENCH
  • 77 POSTS
I am an auto tech and I had an impalla in my shop that did exactly the same thing. I tried everything. to make along story short I took out the radio and found the security wire on the radio plug and cut the wire.Starts every time now .no more problems. repry to this answer and I will tell you how to do it...Jerrygoodwrench...
RADIO1456
Electrical problem
2003 Chevy Impala 6 cyl Four Wheel Drive Automatic 90.100 miles
I have 2003 chevy Impala had car for year now,and for second time the car wont start, i been reading lot on this problen last few hours. When it did it first time i got starter fixed, and today leaving for work wounldnt start, it hasnt started each time i tryed. Its flashing security. Is there some way to get this fixed, to end the problem.
This need to be recalled, before someone get hurt..
Thanks
Mar 12, 2021 at 1:18 AM (Merged)
SATURNTECH9
  • 30,868 POSTS
First thing you need to do is see what code's you have in your body control module then go from there.Most common thing to go wrong is the pas lock sensor's.It's not the easiest thing for a do it your selfer to fix.Because you need a advanced scan tool that can read body control module code's and live data from the body control module to see what the pass lock reading's are when the car isn't starting.
RADIO1456
Is there time line the car will start again or trick to get it to start, so i can get it to the repair shop? The car hasnt started at all when i tryed evey two hours, earlyer today.
SATURNTECH9
  • 30,868 POSTS
give this a try to start it.
TOOLS REQUIRED
None
4. Turn OFF the ignition, and wait 5 seconds .
RADIO1456
my car started late last night before, the steps you sent. Its seens to be starting ok for now.
My other question how long before passlock senser stops reading again? I be taking my car to the shop friday.
Also my alarm system doent look like its been working as well. I tryed some of the steps in the onwers manual and just learn that alarm system not working like it should. Does bad passlock senser have something to do with that?
SATURNTECH9
  • 30,868 POSTS
There is no telling when the next time the car doesn't start that is going to be very random till you get it fixed.You hadn't mentioned your alarm problem's before if the alarm system is causing a false tamper then that could cause a no start and have nothing to do with a bad pass lock issue.You will just have to take it in to which is the case or you could have two problem's the pass lock issue and a alarm issue.Let me know what they find.
RADIO1456
Yea i didnt see any problem with alarm system intell last night, i was reading the onwers manual, and it talked about locking doors. it said when you use power lock swith,before doors are cloesed the light on radio should be on entell you closed the doors and it will start slowing flashing when close the doors. When i lock the doors with power door swich, the light on the radio is still flashing and when i close the doors and there locked it still flashing, nonthing changes.
Is there any way to disaram the alarm system, so this problem will stop intell i get it to the shop?
SATURNTECH9
  • 30,868 POSTS
Here's the problem the newer gm car's use a body control module to run the lock's key less entry alarm mileage light's etc if you shut that down you loose everything.So you need to just hope for the best untill you get it checked out.
KAMAN36
It is simple, when I turn off the vehicle, I take out the key and before I can exit the vehicle the headlight flicker rapidly. If I engage the door locks and shut the doors it will do one of two things 1) flicker once or twice and stop. or 2) continue flickering rapidly, occasionally stopping and restarting every few seconds until I replace the ignition key and turn to "on". Also, upon starting the vehicle each time the drivers door lock will disengage, while already disengaged, over and over for about fifteen to thirty seconds. It is acting as if the car alarm is activating but the pass-lock does not engage so starting the car is not a problem but after a few seconds of motion and while driving the engine will simply turn off. how do I reset the security/alarm/pass-lock for this vehicle?
STEVE W.
  • 15,423 POSTS
That does not sound like the pass-lock system. It sounds like a faulty body control module or steering column wiring harness fault.
Pass-lock does not connect to the headlights, it uses the parking lights,
Pass-lock does not operate the door locks, those are controlled through the BCM and the remote keyless entry system.
Lastly pass-lock shuts of power to the starter not the fuel system.
It can cause a lot of problems but the ones you are having do not point to it.
EMMY83
So I just bought the car and now when I go to start it, the battery and security lights flash. All of the interior lights come on along with the radio. When it happened, I was at a restaurant that, luckily, a friend of mine worked at. She helped me jump my car but nothing happened. So frustrating! I had it towed to my apartment because I didn't and still don't have the money to fix it. I keep hearing/reading it's a security flaw. How can my boyfriend fix this problem? I tried putting the key in the on position until the security light stopped flashing but it never did. I've read several different solutions involving the bcm but I wanna hear it from a pro before we do anything. Please help! Oh, by the way, when I called a Chevy dealership to explain the problem, she kept telling me it couldn't possibly be the security flaw I've been reading about. That it's either the starter or battery. Pshaaa!
Mar 12, 2021 at 1:19 AM (Merged)
try this. trun the key to start and let it come back to the on position. the security light will be on. leave it there till the security light goes out. it could take up to 10 minutes. do this 3 times. after the third time, it should start. if not then there is another issue.
EMMY83
Ok what if we do that and after about 25 30 mins it starts dinging and all of the panel lights come on? Does that mean it's reseting itself?
no, what happened to the security light??
EMMY83
It's still coming on after the battery light. Help me, Roy! This is crazy!
did you follow the procedure and did the light go out?? forget about the battery light till you get it to start
EMMY83
The security light never went off. I did it twice and only twice because the freaking battery died in the process! I'm almost resigned to have it towed to the dealership for the diagnostic alone. My friend Todd, who's a mechanic, told me to have it jumped and hit the starter with some kind of bar to see if it's sticking. I feel like this is the craziest thing I've heard thus far. Eh... I hate this car. More than you could ever know. I think you might need to make a trip to Denver.
AMYSW29
Every few days-week I have a problem starting my car. I took my starter in to get checked and as I recall they cleaned the brushes and repaired a bushing. Anyways, that helped the problem for a little bit but now I am having the problem again. The battery and alternater are working fine. What happens is when I try and start my car it won't turn over. All I get is a clicking sound. I have found that if I continue to start my car..after 10 minutes (almost exactly) it will start. Please give me any sugestions you may have as this is getting to be quit a pain when it happens. Thank you for your time.
RENAUDTN
  • 636 POSTS
That sounds like a typical passlock problem. Passlock is your theft deterrent device.
When your car doesn’t start, does ‘security’ flash on the dash? If so that would confirm a passlock problem.
There’re a few things you can do:
• Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
* Bypass it (check online for infos)
