Reset codes
140,000 MILES
JOSEPH AHURIRI
How or where do I find the reset all engine default codes as mine have been wiped?
Dec 20, 2018 at 7:42 AM
  • 110,251 POSTS
To reset trouble codes, you will need a scanner. Connect the scanner and turn the ignition key to the run position with the engine off. Scroll through until you find delete codes. Select it and follow the prompts. Each scanner is a little different, but that is how it's done.
Here are a couple quick videos that show how to use a scanner. The second video shows ABS codes being deleted.
https://youtu.be/YV3TRZwer8k
https://youtu.be/rTtAnsOlZU4
Dec 20, 2018 at 10:40 AM
