Petrol mixed with diesel?
785,000 MILES • 2.4L • 4 CYL • 2WD
RAMAKWALET
I once poured a petrol that was mixed with diesel, the car started cutting off while moving as much as i press the accelerator it powers off. i drained the diesel mixed petrol changed the plugs and moved almost 100 km but now it's back to that same problem.
Nov 12, 2022 at 10:33 PM
  • 110,248 POSTS
This model isn't offered in the US, but I will try my best to help.
In addition to draining the tank, did you replace the fuel filter, and blow out the fuel line and injectors? It sounds like the mixture is still present in the engine. If you didn't clean the lines, filter, and injectors, that is still present.
Nov 13, 2022 at 9:35 AM
RAMAKWALET
Okay, thanks. I will try that and will get back to you, okay.
Nov 13, 2022 at 7:28 PM
  • 110,248 POSTS
You are very welcome. I look forward to hearing if that takes care of the issue.
Nov 14, 2022 at 11:41 AM
