Reprogramming PCM Ford Laser
2001 FORD LASER
93,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
SUNSARO67
  • 42 POSTS
I replaced the PCM with a junk yard one. Car is cranking but not starting. If I need reprogramming the replaced PCM could you please tell me how to?
Mar 26, 2017 at 4:05 PM
STEVE W.
  • 15,351 POSTS
Programming is not something you can do without having the correct programming tool, access to the factory programming data and then a good scan tool to be sure the programming is correct.
What was the initial reason for replacing the PCM? Crank and no start? If so what testing was done prior to the PCM swap?
Mar 26, 2017 at 9:44 PM
SUNSARO67
  • 42 POSTS
Thanks Steve
The reason for my question is that my son's Ford Laser "HOLD" light flashes and I am not successful after trying few steps like flushing the transmission fluid and replacing the speed sensors as per the repair manual.to fix this problem. The next step is checking the PCM but I do not have the correct equipment. So I wanted to replace the PCM with a junk yard one. If that doesn't fix the problem I understand that I will need to repair or replace the transmission.
Mar 28, 2017 at 11:09 PM
STEVE W.
  • 15,351 POSTS
The flashing light is telling you the trans has a code set. You can get the code(s) read and see if it gives you a hint. The problem with that trans isn't usually in the PCM. It's usually internal.
Mar 29, 2017 at 3:33 AM
SUNSARO67
  • 42 POSTS
Thanks again Steve
The Ford dealer confirmed that the problem is internal. I am going to replace the trans-axle with low km secondhand one. Any advice?
Mar 29, 2017 at 9:32 AM
STEVE W.
  • 15,351 POSTS
Flush out everything very well. Add a larger trans cooler. If there is any reason to suspect that metal might have made it into the factory cooler, replace it.
Other than that I hope the "new" trans makes it a good vehicle again.
Good luck and if you have any other questions come on back and ask, Tell others about us. We're here to help.
Mar 29, 2017 at 12:17 PM
