Replacing transmission mounts and codes P0410, P0171
140,000 MILES • 3.4L • 6 CYL • 2WD
ALEX19899
  • 171 POSTS
Does anyone have pictures of the transmission mounts location? I will be replacing them in a couple of weeks and want to see how hard it is to get them replaced.
Thanks
Feb 20, 2018 at 4:59 PM
Good morning.
The front one is easy. Just be sure you use a floor jack with a piece of wood to jack up the transmission.
The side one is little tight but once again make sure you have the transmission supported.
Feb 20, 2018 at 7:01 PM
ALEX19899
  • 171 POSTS
Thank you. from the pictures you showed me I will only need two transmission mounts?
Feb 20, 2018 at 7:15 PM
Correct, only shows front and side mount.
Feb 20, 2018 at 7:41 PM
ALEX19899
  • 171 POSTS
so I only need these two mounts?
Feb 20, 2018 at 7:58 PM
Correct.
Feb 20, 2018 at 7:59 PM
ALEX19899
  • 171 POSTS
also, I have a code P0410 for the secondary air injection. I already replaced the air pump and both check valves. I am not sure what to check next
Feb 20, 2018 at 8:05 PM
Make sure the passages are clear to the manifolds. common issue for this code.
Does the pump run in the morning?
Feb 20, 2018 at 8:07 PM
Flow chart for the code:
CIRCUIT DESCRIPTION
An AIR pump is used on this vehicle in order to lower the tail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the AIR pump relay control circuit, which energizes the AIR pump. The PCM also grounds the AIR combination valve vacuum control circuit, which energizes the AIR vacuum solenoid valve. Vacuum is then applied to both AIR combination valve diaphragms which open the shut-off valves. The PCM enables both circuits simultaneously when AIR system operation is desired.
When the AIR system is active, the AIR pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR solenoid valves replace the conventional check valves. When the AIR system is inactive the shut-off valves prevent air flow in either direction. DTC P0412 applies to the AIR vacuum control solenoid circuit. DTC P0418 applies to the AIR pump relay control circuit. DTC P0410 sets if an air flow problem is detected.
The PCM will run up to 3 diagnostic tests using the HO2S 1 voltage to diagnose the AIR system. The first is a passive test, it has 2 parts. The 2 parts are the AIR Passive Test 1, and AIR Passive Test 2. The second test is an Active Test, it has one part. This test is named AIR Active Test.
The AIR Passive/Active Tests consist of the following:
AIR Passive Test 1
^ When the AIR system is enabled, the PCM monitors the HO2S 1 voltage for a specific amount of time calculated by the coolant temperature at start-up. The HO2S 1 is monitored for 10 seconds if the coolant temperature is more than 90°C (194°F), or 70 seconds if the coolant temperature is less than 90°C (194°F).
^ If the HO2S 1 voltage goes below a calibrated amount, the PCM interprets this as an indication the AIR System is operational and it is considered a test passed.
^ When the AIR Passive Test 1 completes, the PCM then runs the AIR Passive Test 2.
AIR Passive Test 2
^ When the AIR System is disabled, the PCM monitors the HO2S 1 voltage. The HO2S 1 voltage should increase above a calibrated amount and switch normally.
^ When the AIR Passive Test 2 is complete and both AIR Passive tests indicate a pass, no further action is taken. If either one of the above tests have failed or is inconclusive, the diagnostic will proceed to the AIR Active Test.
AIR Active Test
^ During this test the PCM turns the AIR system on during Closed Loop operation. When the AIR system is activated, the PCM monitors the HO2S voltage. If the AIR system is operating properly, the HO2S 1 voltage should go below a predetermined level.
^ The PCM will repeat this test up to 3 consecutive times with a short delay between each command.
^ If the PCM determines that the HO2S 1 voltage did not respond as expected during the tests, DTC P0410 will set.
CONDITIONS FOR RUNNING THE DTC
^ DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0171, P0172, P0300, P0412, P0418, P0442, P0443, P1441, and HO2S are not set.
^ The engine operates for more than 2 seconds.
CONDITION FOR NOT PASSING AIR ACTIVE TEST
The HO2S 1 voltage changes less than 0.06 or is more than 225 mV for 1.5 seconds during 2.5 seconds of AIR pump operation.
CONDITIONS FOR SETTING THE DTC
^ The pre-catalyst HO2S voltage remains above 300 mV (Passive) or 150 mV (Active) for a calibrated period of time.
AND
^ The Short Term FT does not increase a calibrated amount during the test.
^ Both the above conditions exist for 3 consecutive tests.
ACTION TAKEN WHEN THE DTC SETS
^ The PCM will illuminate the Malfunction Indicator Lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed.
^ The PCM will store conditions which were present when the DTC set as Freeze Frame and Failure Records data.
^ If the misfire is determined to be catalyst damaging, the PCM will flash the MIL.
CONDITIONS FOR CLEARING THE MIL/DTC
^ The PCM will turn OFF the MIL during the third consecutive trip in which the diagnostic has been run and passed.
^ The History DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
^ The DTC can be cleared by using a scan tool.
DIAGNOSTIC AIDS
Inspect for the following:
IMPORTANT: Remove any debris from the connector surfaces before servicing a component. Inspect the connector gaskets when diagnosing or replacing a component. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion.
^ Faulty terminal connection - Inspect the harness connectors for the following conditions:
- Backed out terminals
- Improper mating
- Broken locks
- Improperly formed or damaged terminals
- Faulty terminal to wire connection- Use a corresponding mating terminal to test for proper tension. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Diagrams.
^ Damaged harness - Inspect the wiring harness for damage.
If the harness inspection does not reveal a problem, observe the display on the scan tool while moving connectors and wiring harnesses related to the sensor. A change in the scan tool display may indicate the location of the fault. Refer to Circuit Testing and Wiring Repairs in Diagrams.
^ Clean and secure connections at the PCM and the engine grounds.
If the DTC is determined to be intermittent, reviewing the Failure Records can be useful in determining when the DTC was last set.
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table:
2. DTC P0412 AIR Solenoid Valve Control Circuit and P0418 AIR Pump Relay Control Circuit should be diagnosed first if either are set.
3. This step begins testing for a short to ground in the AIR pump feed circuit.
4. Listen for a running motor, command both the ON and OFF states. Repeat the commands as necessary.
5. This step begins testing for a short to voltage in the pump feed circuit.
6. This step tests for voltage at the AIR pump relay switch feed circuit.
7. This step bypasses the relay.
9. This step tests for voltage on the AIR pump feed circuit.
10. This step tests for an open on the pump ground circuit.
29. The AIR Pump is not designed to run continuously. If the pump needs to be replaced, inspect for conditions that may cause continuous pump operation.
Feb 20, 2018 at 8:10 PM
ALEX19899
  • 171 POSTS
yes the pump comes on for about a minute then shuts off. last month I had the vacuum hoses replaced and also intake manifold gasket as well. the code will not come on until about twenty minutes of me driving and a few days ago code P0171 came on. not sure if that has anything to do with the P0410.
Feb 20, 2018 at 8:28 PM
171 is a lean code which indicates a vacuum leak. Make sure the purge valve at the back exhaust manifold is connected.
Feb 20, 2018 at 9:26 PM
ALEX19899
  • 171 POSTS
so this code just pop up. now since the other codes pooped up as well would they correspond with each other?
Feb 24, 2018 at 4:39 PM
This is related to the 410 code as the pump is to add additional O2 to the exhaust
Feb 24, 2018 at 7:48 PM
ALEX19899
  • 171 POSTS
thought so I just find It weird that I finally get the code for o2 sensor when I had the code for air pump about a month lol
Feb 24, 2018 at 8:26 PM
Yep. takes time for the code to set. the pcm tests the system and it has to fail the test 3 times in a row before it sets a hard code.
Feb 24, 2018 at 8:34 PM
ALEX19899
  • 171 POSTS
so is the o2 sensor that I need to replace upstream?
Feb 24, 2018 at 9:41 PM
No, nothing says that the O2 sensor is at fault. Checks need to be done to verify the failure.
it could be a vacuum leak, the pcm needs to see a change in the reading to indicate excessive O2 in the system.
Feb 24, 2018 at 10:50 PM
ALEX19899
  • 171 POSTS
do you know how many o2 sensors my car have?
Feb 25, 2018 at 7:43 AM
2. One upstream and one downstream.
they are not your issue and will not resolve the issue
Feb 25, 2018 at 7:47 AM
ALEX19899
  • 171 POSTS
downstream o2 sensor is showing 0.2 voltage
Feb 25, 2018 at 8:36 AM
ok, the only job the downstream has is to monitor the cat converter. it has no effect on any other system.
it should read a relatively steady voltage as the front sensor will vary in voltage.
Feb 25, 2018 at 8:41 AM
ALEX19899
  • 171 POSTS
what's the job of the upstream sensor
Feb 25, 2018 at 8:45 AM
Monitor the fuel mapping. the up and down voltages you see are rich/lean signals being sent to the pcm to adjust injector on times
Feb 25, 2018 at 8:51 AM
ALEX19899
  • 171 POSTS
I inspected the exhaust system and I found several holes throughout the pipes.
Feb 27, 2018 at 7:31 AM
OK, where were they located??
Feb 27, 2018 at 7:37 AM
ALEX19899
  • 171 POSTS
after the downstream o2 sensor
Feb 27, 2018 at 7:40 AM
Ok, thanks. That will not effect the O2 readings. It will only effect the reading if it is before the sensor.
Feb 27, 2018 at 7:47 AM
ALEX19899
  • 171 POSTS
here s a pic
Feb 27, 2018 at 8:19 AM
That is the muffler.
Feb 27, 2018 at 8:23 AM
ALEX19899
  • 171 POSTS
ohhhh what problems would I have if I continued to drive it like that ?
Feb 27, 2018 at 8:34 AM
It will not effect the driving. It will just keep the light on until you have it repaired.
Feb 27, 2018 at 8:37 AM
