No, but there are a few resets that need to be done once it's installed. Reset Memory, yaw rate and acceleration sensor zero point calibration, and CVT oil pressure calibration all need to be done.
RESET MEMORY
Turn the ignition switch off.
Move the shift lever to P and apply the parking brake.
Connect the scan tool
Turn the ignition switch to ON don't start the engine
Go into the powertrain and find the setting to reset the memory.
Select it and follow the prompts.
Next perform the deceleration sensor zero point calibration
Key on engine off. Vehicle stable, try to not vibrate or move the vehicle during calibration
Go into the scan tool and locate the menu for the sensor and let it calibrate the sensor.
Turn the ignition switch off and wait at least 30 seconds.
Turn the ignition switch to ON and wait at least 2 seconds.
Start the engine and wait at least 5 seconds.
Now go into powertrain and locate the CVT oil pressure calibration.
You should hear the idle change while it calibrates.
Once complete shut the engine off and do the CVT fluid degradation reset (transmission oil life)
This one is common on many CVT equipped vehicles, you do a reset whenever the fluid is changed, just like an oil life reset.
Key on engine off
Go into the powertrain menu and find the ATF thermal fluid degradation and follow the prompts to reset it.
Now it will need to be driven to allow it to relearn some of the parameters.
Oct 24, 2026 at 8:14 AM
