replacing the water pump
1986 ALFA ROMEO SPIDER
160,000 MILES
WOOF
how do you replace the water pump
May 1, 2013 at 11:15 AM
JDL
  • 16,098 POSTS
My info on your water pump is fairly basic. Drain the cooling system. Remove radiator. Disconnect tachometer drive, if equipped. Remove hoses and fan belt. Remove mounting nuts and remove water pump. Install is reverse of removal.
You may have to remove crankshaft pulley. If that is the case, remove flywheel inspection cover, use small tool to keep flywheel from turning, So you can remove crankshaft pulley.
May 1, 2013 at 12:36 PM
