Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Engine
Timing Chain
Cover
Gasket
Replacing the timing chain cover gasket
2003 CHEVROLET CAVALIER
152,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JJAMES60
MEMBER
Is there a motor mount under the timing chain cover that has to be removed to take off the gasket?
Jun 21, 2022 at 4:28 AM
SQM
Experienced Mechanic
You will have to remove the harmonic balancer and belt tensioner before removing the front cover. Motor mount removal is not needed.
I have attached the procedure below for your reference.
Let me know of any questions
Images (Click to enlarge)
Jun 21, 2022 at 8:31 AM
JJAMES60
MEMBER
Thank you so very much.
Jun 21, 2022 at 9:28 AM
SQM
You are welcome.
Thank you for using 2CarPros.
Jun 21, 2022 at 12:58 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
