Starter motor replacement instructions needed
135,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
GARY ATKINS
How do I replace the starter motor?
Mar 27, 2021 at 5:36 AM
  • 110,246 POSTS
Note: You indicated the engine as a 1.4L. That was never an option. I am including directions for the 1.6L. If that is incorrect, please let me know.
Replacing the starter really isn't too hard. Please make sure to disconnect the battery before you start the procedure.
To get you started, here is a link that shows in general how it is done. Use this as a guide because it provides direction and pics to help you locate different things.
Because of the model year, the manual is somewhat basic as far as replacement directions. However, here they are.
1997 Nissan-Datsun Sentra L4-1597cc 1.6L DOHC MFI (GA16DE)
Procedures
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures
PROCEDURES
REMOVAL
1. Remove battery negative cable from battery.
2. Remove intake air duct.
3. Remove starter motor mounting bolts.
4. Remove battery cable from starter motor.
5. Disconnect harness connector from starter motor harness.
6. Remove starter motor:
- from transaxle side [GA engine (M/T)].
- from engine side [GA engine (A/T)].
INSTALLATION
The installation procedure is basically the reverse order of removal.
Torque: 31 - 42 N-m (3.3 - 4.3 kg-m, 23 - 31ft-lb)
________________________________
I hope this helps. Let me know if you have other questions or run into trouble.
Mar 27, 2021 at 1:50 PM
