Replacing the A/C pulley or sprocket
144,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GARYJA8
The top pulley or sprocket in the serpentine belt system is wobbly and moves loosely in and out. It needs to be replaced. How do take it off?
Feb 6, 2020 at 8:00 AM
JOETECHPRO
  • 705 POSTS
Hey GARYJA8,
I have attached the instructions for replacing the power steering pulley on your vehicle below.
Before replacing i would advise checking if the play is in the pulley, ie the pulley is loose on the shaft/the pulley is out of shape, or that the power steering pump shaft has play and is causing the wobble you are experiencing. It may be that you require a new PAS pump and not a new pulley.
Let me know if you have any further questions.
Regards, Joe
Feb 6, 2020 at 9:53 AM
BMDOUBLE
  • 1,139 POSTS
I agree! I think you are having pump issues!
Feb 7, 2020 at 2:33 AM
