Replacing the abs brake computer mod.
1993 TOYOTA CAMRY
100,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
KIP9666
I am interested in more info, how do I replace the abs brake module Recently asked about brake light on dash panel will replacement of this eliminate the brake light on dash panel remaining on after replacing calipers, flex lines and brake pads for good measure. After bleeding lines several times the dragging or grabbing problem still percists could it be possible to have a contaminated line?
Nov 28, 2014 at 10:17 AM
HMAC300
  • 48,601 POSTS
have a pro scan it as it may not be the module it may be a sensor or a broken wire which will show up on the scanner
Nov 28, 2014 at 10:54 PM
