Replacing strut assembly
98,021 MILES
CORY2427
  • 293 POSTS
Was wondering if anything had to come apart to change it out and if I need spring compressor? Every video I watched shows taking everything apart and need spring compressor.
Jul 30, 2018 at 1:57 AM
CORY2427
  • 293 POSTS
Here are pictures of bottom and top.
Jul 30, 2018 at 1:59 AM
DANNY L
  • 5,648 POSTS
Hello again.
I have attached a step-by-step for you. You will only need a spring compressor if you have a coil spring and shock assembly. A strut assembly does not require one. This is for your strut assembly. Hope this helps.
Danny-
Jul 30, 2018 at 4:57 AM
CORY2427
  • 293 POSTS
So I do need to support lower control arm?
Jul 30, 2018 at 5:34 AM
DANNY L
  • 5,648 POSTS
Hello again.
I would not. I would support the truck from the frame and let the control arms droop. The lower they can droop down the easier you can remove the strut assembly out. Hope this helps.
Danny-
Jul 30, 2018 at 5:43 AM
CORY2427
  • 293 POSTS
Will they even drop because so much stuff still hooked up?
Jul 30, 2018 at 6:00 AM
DANNY L
  • 5,648 POSTS
Hello.
Yes, once you remove the mounting nuts and bolts it will drop enough for you to be able to remove the strut assembly.
Danny-
Jul 30, 2018 at 6:09 AM
