replacing same fascia that forcibly removed
2007 NISSAN ALTIMA
185,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
CMZANNN
  • 84 POSTS
the front fascia was forcibly removed wheel to wheel. can you guide me in this?
Aug 11, 2020 at 3:24 AM
Good afternoon,
Can you upload some pictures of what is missing?
I need to see what you see.
Aug 11, 2020 at 6:17 AM
CMZANNN
  • 84 POSTS
Roy. hey, just saw message. i can shoot you pics in the am. two pieces i recovered; the bumper/grille intact and plastic piece that mounts behind it.
Aug 11, 2020 at 6:05 PM
Okay, I will be waiting for the pictures.
Aug 11, 2020 at 9:34 PM
CMZANNN
  • 84 POSTS
Roy, you still have trigger and bullet. kidding, i think. after i just came in from looking over my problem it's pretty self explanatory. thanks so much. i'm going to take a shot at it tomorrow.
Aug 12, 2020 at 3:47 PM
You are welcome.
Let me know if you need any further help.
Aug 12, 2020 at 8:49 PM
CMZANNN
  • 84 POSTS
thanks for all your support. i got it. thanks again.
Aug 15, 2020 at 12:48 AM
CMZANNN
  • 84 POSTS
thanks for all your support ..i got it...thanks again
Anytime.
We are here to help.
Aug 15, 2020 at 8:52 AM
CMZANNN
  • 84 POSTS
Roy,i got front fascia on and secure,but the hood,when it's closed will depending on surface ,the hood will pop loose causing it to only stay closed. Because the first part of latch keeps it the hood from opening and causing a very bad situation.. the latch mechanism does not appear damaged. how do i get it to work properly?
Aug 21, 2020 at 6:14 AM
There should be 2 bolts for the hood latch. Loosen them up and lift up the latch a little and tighten the bolts. Then close the hood and see if it stays.
Aug 21, 2020 at 7:17 AM
CMZANNN
  • 84 POSTS
after going to 3 stores to find a socket to fit i'm going to go and see if loosing the 3 bolts lifting up the unit and tightening. will let you know.
Aug 24, 2020 at 2:05 AM
Sounds like a plan.
Aug 24, 2020 at 6:24 AM
CMZANNN
  • 84 POSTS
Okay Roy, I loosened up three bolts didn't get much play, it is a little better.. i was just thinking when this happened I drove the car a couple of days without facia on the car. the hood double latched no problem.. any thoughts?
Aug 24, 2020 at 2:04 PM
This is a result of the accident. The mount for the latch is bent not allowing the hood to latch securely.
If you cannot get the adjustment correct, you will have to have the car checked to see if the bar it is mounted on is bent.
Aug 24, 2020 at 7:21 PM
CMZANNN
  • 84 POSTS
when the facia was off hood latched okay.
Aug 25, 2020 at 4:50 AM
Okay, then make sure the facia is not blocking the hood too close.
Can you upload some pictures for me to view?
Aug 25, 2020 at 5:36 AM
CMZANNN
  • 84 POSTS
i will try Roy. i'm going to go out there in awhile i also think facia is blocking full closing of hood. it is still hot here and my immune system is still messed up with effects of chemo. i will get back at you ASAP.. thanks again for all the help.
Aug 25, 2020 at 6:14 AM
You are welcome.
Keep me updated.
Aug 25, 2020 at 6:16 AM
CMZANNN
  • 84 POSTS
I'm trying to upload.
Aug 25, 2020 at 10:37 AM
CMZANNN
  • 84 POSTS
i'm tryin to upload picture but phone needs to be charged. I will get back to you when it charges.
Aug 25, 2020 at 10:49 AM
Sounds good. We will be here for you.
Aug 25, 2020 at 7:04 PM
