Replacing rotors
254,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JUSTIN_DAVIDSON
What torque spec is it to attach the rotor (disk) to the hub? Your YouTube video used a pneumatic gun and did not say the torque specs.
May 12, 2018 at 1:22 PM
JIS001
  • 3,412 POSTS
If installing the rotor back on then tightening torque spec is 47 ft.lb. star pattern.
Hear is a video that shows the job being done.
https://youtu.be/p6smTU_SnPg
This guide will help as well
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
May 12, 2018 at 4:14 PM
JUSTIN_DAVIDSON
This torque spec, see picture (rotor disk to hub). Not the torque for attaching the wheel back on. Unless its the same spec of 83 foot pounds.
May 12, 2018 at 4:44 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
47 ft lbs.
May 13, 2018 at 12:13 AM
JIS001
  • 3,412 POSTS
Thank you PATENTED_REPAIR_PRO.
May 13, 2018 at 5:19 AM
