How difficult is it to just replace the rod bearings if they have play in them?
125,000 MILES • 4 CYL • 2WD • MANUAL
BHAMDOC1973
  • 2,007 POSTS
We replaced the chain as it had a bit of noise, we still have some noise coming from the bottom of the engine. This is the 2.5 sky active engine.
May 17, 2023 at 2:06 AM
  • 55,694 POSTS
It is not too bad to do the rod bearing. You will need to remove the oil pan first, which I have included the instructions for in the images below.
for the SkyActiv-G 2.5L engine commonly found in the 2015 Mazda 6, the connecting rod bolt torque is typically around 33-38 lb-ft (45-52 Nm)
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 17, 2023 at 4:32 AM
BHAMDOC1973
  • 2,007 POSTS
Thanks.
May 17, 2023 at 4:47 AM
  • 55,694 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 18, 2023 at 4:33 AM
BHAMDOC1973
  • 2,007 POSTS
Not as simple as I thought it would be. I thought i would be able to see the bearings from below. Geez
May 20, 2023 at 1:37 AM
  • 55,694 POSTS
That is the balance shaft assembly. Here are the instructions on how to remove it. Check out the images (below). Please let us know what happens.
May 21, 2023 at 4:32 AM
BHAMDOC1973
  • 2,007 POSTS
Yes, i don't want to fool with chains. I'll get another motor.
May 21, 2023 at 4:45 AM
  • 55,694 POSTS
Sounds good.
May 22, 2023 at 3:45 AM
