Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
6
Engine
Piston
Rod
Bearing
How difficult is it to just replace the rod bearings if they have play in them?
2015 MAZDA 6
125,000 MILES • 4 CYL • 2WD • MANUAL
BHAMDOC1973
MEMBER
We replaced the chain as it had a bit of noise, we still have some noise coming from the bottom of the engine. This is the 2.5 sky active engine.
May 17, 2023 at 2:06 AM
Experienced Mechanic
It is not too bad to do the rod bearing. You will need to remove the oil pan first, which I have included the instructions for in the images below.
for the SkyActiv-G 2.5L engine commonly found in the 2015 Mazda 6, the connecting rod bolt torque is typically around 33-38 lb-ft (45-52 Nm)
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Images (Click to enlarge)
May 17, 2023 at 4:32 AM
BHAMDOC1973
MEMBER
Thanks.
May 17, 2023 at 4:47 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 18, 2023 at 4:33 AM
BHAMDOC1973
MEMBER
Not as simple as I thought it would be. I thought i would be able to see the bearings from below. Geez
Image (Click to enlarge)
May 20, 2023 at 1:37 AM
That is the balance shaft assembly. Here are the instructions on how to remove it. Check out the images (below). Please let us know what happens.
May 21, 2023 at 4:32 AM
BHAMDOC1973
MEMBER
Yes, i don't want to fool with chains. I'll get another motor.
May 21, 2023 at 4:45 AM
Sounds good.
May 22, 2023 at 3:45 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
