Replacing rocker panels
200,101 MILES • 4.8L • V8 • 4WD • AUTOMATIC
CHRISI
Rocker panels on both sides are rusted,crusty,corroded and just about gone. Truck is an ext.cab.
Aug 8, 2019 at 2:59 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
Rocker replacement is pretty straight forward. Start by clamping up the new rocker and deciding where you need to cut the old at. You can either cut them and do a butt weld or cut, flange and plug weld the new ones on. Sleeving the new and old and plug welding is another option. Sleeving will give the most strength. Make sure you use a weld through primer and cavity was behind the panels once welded up.
Aug 8, 2019 at 4:44 PM
