Replacing ignition switch and new keys cut and programmed?
177,000 MILES • 3.3L • 6 CYL • 2WD • MANUAL
CHRISTINA KAY MCCOOL
Lost keys about 2 years ago tried to drive anyway broke ignition switch and signal coil around ignition switch.
Mar 18, 2023 at 10:50 PM
  • 55,770 POSTS
Hi Christina,
I am not sure what you are asking, do you need instructions to install the new switch if so, here is how the job is done in the images below, but if you can upload an image of the problem, I can help you better. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Mar 19, 2023 at 6:21 AM
