Fuse box replacement instructions needed
85,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
DIVIDES
  • 903 POSTS
This is a 12-countryman s all4 trim automatic. I need to replace the fuse box on the passenger side behind kick panel. Can you see if you can find instructions? And whether any programming is needed?
Jan 18, 2022 at 6:56 AM
SQM
  • 6,383 POSTS
Replacing the fuse is fairly straight forward.
However, this will need programming after replacement.
Unfortunately, Alldata does not provide programming info or steps.
I have attached the replacement instructions below.
Jan 18, 2022 at 7:47 AM
DIVIDES
  • 903 POSTS
Ugh, programming. Is that something my Maxisys would do you think? Or must be a dealer thing?
Jan 18, 2022 at 7:58 AM
SQM
  • 6,383 POSTS
This is more of a dealer thing, unfortunately.
Jan 18, 2022 at 8:20 AM
