Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
STS
Drivetrain
Bearing Hub
Replace/Remove
replacing front wheel hubs?
2008 CADILLAC STS
170,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
CANDO1
MEMBER
please send information with tightening foot lbs specs for new wheel bearing hub.
Feb 17, 2025 at 2:26 AM
Experienced Mechanic
Sure, here is how to change out the front bearing hubs with torque specs as requested.
Tighten the wheel bearing/hub mounting bolts to 135 N.m (100 lb ft).
Install a new wheel driveshaft retaining nut Tighten the nut to 160 N.m (118 lb ft).
Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Feb 18, 2025 at 3:50 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
