How to replace the front strut?
140,000 MILES • V8 • 4WD • AUTOMATIC
BHAMDOC1
  • 399 POSTS
This is an 07 Benz E550 but I did not see an option for the 550. It's 4matic. I need to replace the front air strut as it is very bouncy. Driver side.
Feb 26, 2022 at 9:32 AM
When you say the air strut, I assume you are not talking about the spring because that would not cause a bouncy feeling.
So, I am attaching the info on both the spring and strut just to ensure I give you what is in the manual.
However, here is a video that is on a similar vehicle that will help with this:
https://youtu.be/tXnyEEFlFnA
Please see the attached info and let us know how you make out with this.
Thanks
Feb 27, 2022 at 10:55 AM
DIVIDES
  • 903 POSTS
No there isn't a spring on it. Just an air strut. Car is leveled bit when you push down on the hood from that side it is so bouncy, the other 3 are fine.
Feb 27, 2022 at 11:09 AM
Got it. Thanks for the update. Good to hear from you.
Feb 27, 2022 at 10:00 PM
