Replacing front brake pads
205,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DYCAR2008
  • 18 POSTS
How do you replace the front brake pads on the car listed above DX model?
Apr 16, 2020 at 1:43 PM
  • 110,251 POSTS
The directions I provide will be for brake pad and rotor replacement. If the rotors are good, just ignore that portion of the directions.
First, here is a link that shows in general how it is done. I like adding this link as a reference for people to follow.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Here are the directions from the manual. Basically, the directions are in pic 1. This is the reason I like adding the link above.
__________________________________________________
2003 Mazda Protege L4-2.0L DOHC
Front
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Front
FRONT
DISC PAD (FRONT) REPLACEMENT
pic 1
1. Remove in the order indicated in the table.
2. Install in the reverse order of removal.
I hope this helps. If you have questions, need help, or are having trouble, I'll be here so let me know if I can help.
Apr 16, 2020 at 2:04 PM
