how long does it usually take to replace a flywheel/flexplate
Apr 13, 2016 at 5:13 AM
HMAC300
✓Experienced Mechanic
This is a big job and takes about 8.5 hours at the shops labor rate of $85.00 to would be $722.50 Here is a video and diagrams below to show you what it will take to change the flywheel.
This video will give you an idea of how the pull the transmission, its a different car but the procedure is the same.
Cheers
Images (Click to enlarge)
Apr 13, 2016 at 5:25 AM
LIZZY55
MEMBER
1 POST
My mechanic says the labor to install new fly wheel and starter is high because you have to drop the engine. Is this true?
Oct 1, 2018 at 4:57 AM
(Merged)
CARADIODOC
Either that or remove the transmission. The flywheel / flex plate is between the transmission and engine and connects the two of them together. It is indeed a big job to replace it. You can expect it to take between six and eight hours.
(Merged)
SHAWN EAKER
MEMBER
1 POST
1994 Mercury Sable 6 cyl Two Wheel Drive Automatic 150k miles
do i have to drop the transmission to remove the flywheel.
