Engine swap
1997 SUZUKI VITARA
280,000 MILES • 2.2L • V6 • 4WD • MANUAL
KAROLYN BUSH
Can I use the engine from a 2001 Suzuki xl-7 2.7lt v6 (manual) to replace the engine in my 1997 Suzuki Vitara 2lt v6? I’ve been offered the car but don’t know if it will fit/ be compatible, etc?
Fixing the vitara as the body of xl is unrepairable.
Jun 13, 2020 at 6:07 AM
Good morning,
They both have to be 2.7 engines. You did not indicate the donor was a 2.7.
If it is, it will fit but needs modifications and there are differences between the years for the motor.
Can you give me the VIN numbers from both vehicles?
Jun 13, 2020 at 6:18 AM
KAROLYN BUSH
Unfortunately, I don’t have the xl, I’m considering buying it if it’s compatible.
Thank you for your help but I think I’ve resolved my issue.
Jun 13, 2020 at 7:34 PM
You are welcome.
We are always glad to help.
Jun 14, 2020 at 4:14 AM
